white wetinghouse washer model mw3445res0
Old 08-23-08, 01:40 PM
G
Washing machine was making squealing noise and smelled burned rubber. I have taken off the front panel. When I removed the agitator I found massive gunk and am now trying to get the inner tub out so that I can clean it. I've removed the 5 screws (?) that hold the tub down and the outer ring but cannot get the tub out. Is there a screw I've missed. Can I hammer a flat edged screwdriver between the tub and the agitator assembly thingie to loosen it?
Any help or suggestions are appreciated
Old 08-23-08, 01:43 PM
G
correction on model number
sorry model number is mws445res0
Old 08-23-08, 06:19 PM
pugsl's Avatar
Received 75 Votes on 68 Posts
Here is a link to your machine.
http://www.searspartsdirect.com/part...res0&pop=flush
Tub should come out after you loosen the bolts. You have a Frigidaire Washer. transmissions usually the problem with these.
