Crosley Washer Severe Wobble
Old 08-27-08, 05:47 PM
Ran good for 3 years. Now every second load on spin cycle a severe wobble (load imbalance) happens for no good reason. Washer isn't overloaded.
Tipped washer on face and checked is all was tight underneath. Noticed 4 springs that hold the tub and appear to be OK.
The wobble is so severe that self leveling feet get hung up and do not level themselves unless I shake the washer around to release them.
Any ideas on cause or what to look for.
Old 08-28-08, 03:45 AM
pugsl's Avatar
Upvotes Received: 13
Please give model #, I think that washer is based on Maytag but not sure. Maytag have had balance problems.
Old 08-28-08, 05:15 PM
Crosley walking washer
Pugs,
Believe you are correct on the Maytag design. At least that is what we were told when we purchased the washer.
Make: Crosley
Model: CW6000
Purchased in 2000.
Old 08-29-08, 03:50 AM
pugsl's Avatar
1st look for a Aww or Ayw something after model # if needed at least the a part. You have the machine that has the problem. Open lid and see if basket is leaning off to a side someway. Here is a link to your machine
http://www.searspartsdirect.com/part...Number=CW6000a
Might not be right machine I gyessed in the a part of model #. Look under base and parts 18 and 34 are what you need. Had me confused when you said 4 springs there are 6 springs on this model. Springs and snubber are a pain to change. Can give a break down on repair it you want.
Old 09-06-08, 07:18 AM
Thanks for the tips. You are correct there are 6 springs. What I have done so far is lubricate the self leveling foot mechanism and significant improvement has been observed. Yes the tub does lean to one side so I will contact repair man and have the springs and snubber changed.
