mrskeatyn
Kenmore washing machine will not fill with cold water. checked the water line hose and cleaned out the screen and then checked the inlet valve. The cold water side looks as if it was blown out and melted. Could it be to just replace the inlet valve or should I install the wire that is connected to it as well?
You will need to replace the water fill valve. If wires are melted I would also replace them. Have never seen a valve melted, you may have other problems also.
