My Kenmore 80 Series
Old 11-13-08, 06:14 AM
B
Unhappy My Kenmore 80 Series
Starting earlier this week it would get to the rinse cycle and stop, it refused to drain, but if I moved the dial to spin it would finish up fine. Then for a few loads it was fine. Today on a small load of whites it sounded off balance so I went to go check on it and the whole "bowl" is off whatever holds it in and it is back to refusing to drain, not even when I move the dial. Please please please say there is a fix to this...
Old 11-13-08, 03:09 PM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
You probably need a lid switch. Please give model # and can help. Usually you can put your hand under the switch and hold it up and use a pen to push lever down( the timer in spin cycle and on) you can get it to spin and drain, you will need to replace switch.
