Amana Side by Side Refrigerator Not Cooling
Old 12-14-08, 08:31 PM
6
Model # SRD26VE
Manf # P1315201WE
Serial # 9810211525
Fan on back of refrig is running but fan in freezer not running. Compressor is warm but not hot. Cooling fins in freezer are not frozen up. Do you have any suggestions on fixing?
Old 12-15-08, 07:51 AM
H
If the compressor is running, so should the fan in the freezer section. Coils in freezer section should have a light coating of hard ice on them when the compressor has been running for 1/2 hour steady. You may have the newer type of evaporator fan in the freezer that is 12 volt dc, or the older better type that run on 110 volts ac. First thing is to check the fan and see which type it is, then measure the voltage to see if that is right, and report back.
H.
