Maytag Quiet Series 100 door latch
Old 12-15-08, 06:58 PM
A
Hello,
The door latch is broken. Looks like the spring got loose - the latch does not return into initial position after I push it up. I can open/close the door but... it takes some time
Is it an easy fix? Could you please direct me to the schematic diagram or/and directions on how to fix that. Do I need to worry about anything after I unscrew the security screws on the front door?
TIA, Alex.
Old 12-16-08, 03:35 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
What type of machine are talking about ? Washer, Stove ? Please give model #. If washer Top or front loader. Tks
Old 12-16-08, 05:15 AM
A
No, it's a dishwasher. Model number is MDBH950AWQ
Old 12-26-08, 06:29 AM
O
Maytag Quiet Series 100 Door Latch Problem
I have a model MDBTT59AWW Maytag Quiet Series 100 and have what sounds like the same door latch problem. I'd like to try to fix it myself first, but I'm concerned about taking the screws out of the door and what I might hurt in the process. Is this something that is easily fixed, and if so, how? Thanks.
Old 12-26-08, 07:42 AM
apwagner's Avatar
Maytag Diagram
Hi, I found a diagram for your Maytag door. Hope this helps!
http://www.apwagner.com/images/diagr...080/i95095.GIF
Old 12-31-08, 05:43 PM
O
Thank you for posting the diagram. I did fix this myself - after I took the screws out of the door I had to replace the entire door latch assembly. It was a relatively easy fix. I appreciate the help! Happy New Year!
