Amana dryer problems
Old 01-03-09, 08:10 PM
D
Question Amana dryer problems
Help. I have an amana gas dryer that works perfect for the first 5 min. then the flame goes out and will not come back on. At that piont the timer stops and the dryer runs forever with no heat. I have already put in a timer and checked the thermostats with an ohmmeter. All seems OK, but still have a problem, I can't afford a new one yet.
Old 01-03-09, 11:29 PM
D
If you let it sit awhile and then try it again will the heat come back on?
Old 01-04-09, 05:10 AM
its the coils on the valve. they only work when they are cold when they go bad
Old 01-04-09, 09:01 AM
D
yes, it sure does. Works just fine if it sets 10 mins.
Old 01-04-09, 09:05 AM
D
The coils on the gas valve, Correct ? is this a replacable part
Old 01-04-09, 10:59 AM
yes you can buy just the coils, get both
Old 01-04-09, 01:47 PM
Exclamation Armana Dryer problems
My heat wasnt workin and then I took the dryer apart and I managed to loosen the belt. It hasnt popped Its just off track. How do I put it back on???
Old 01-04-09, 02:01 PM
Old 01-04-09, 07:36 PM
D
Old 01-09-09, 08:59 PM
D
Thumbs up success
Can't thank you enough, The coils did the trick.
