Rear leveling leg broken washer jumps around
Old 02-22-09, 08:46 AM
Q
Question Rear leveling leg broken washer jumps around
Ge model WHSR2070V2WB wash machine and the left rear leveling leg does not stay down to keep it level.
How do I get to this to see if it is repairable?
Thanks
Old 02-22-09, 10:34 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
Rear legs are self leveling. Tilt machine forward until you hear a click from back and set back down. If you do not hear a click the legs are jammed and will need to be loosened usually be tilting machine forward and moving legs up and down until they free. Let us know how it turns out.
Old 02-22-09, 12:18 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
just play this when the machine is running. it won't fix the problem but it will make things seem better.
House Of Pain Jump Around Music Video on Yahoo! Music
Old 02-22-09, 04:58 PM
Q
I have moved the rear legs. The right leg I can move up and down freely, the left side does not move easily and the exposed rollpin does not travel the full length of the slot in the back panel. When I set it back down the left leg does not stay extended.
Old 02-22-09, 04:59 PM
pugsl's Avatar
Have to free it up or replace it.
Old 02-22-09, 05:01 PM
Q
My question is how do I get into it to do anything with it?
Old 02-23-09, 04:17 AM
you can see whats going on better if you take the front panel off. take a putty knife and stick it in where the 2 clips are at top of front panel and pull top of panel out.
