Maytag washer leaking
Old 03-23-09, 05:33 PM
Model# LAT9200AAW, water is leaking from the plastic injector sleeve. I have looked at a parts breakdown and appears the only serviceable part would be the rubber injector valve as the plastic sleeve or nozzle does not look as though it could wear or fail. I have the PN# PS2019175 I am just curious if it appears my diagnosis is correct and what function this part performs. If there is something else that would cause water to exit the injector sleeve please advise.
Thanks
Old 03-23-09, 05:43 PM
all you need is the injector valve.
my understanding is that the purpose of this is so that water from the tub can not go back into the fresh water
Old 03-23-09, 06:02 PM
Got it, Thanks for the quick response
Old 03-24-09, 12:32 PM
Injector nozzle installed, no more leak.
Thanks again
