Lady Kenmore 90 series knob
Old 04-04-09, 10:42 AM
We have a lady kenmore 90 series and the dial (setting time, etc.) lost its friction. That is, I can use a screw driver, key or something to press on the dial to rotate it. However, the knob doesn't function. I looked up the parts online, but couldn't locate a manual or way to remove all the parts. Any suggestion on how I can go about removing old one and replacing with new one?
http://www.searspartsdirect.com/part...ponents%20list
Old 04-04-09, 11:21 AM
follow up
I found this link - Major Appliances: Timer control, timer control, set screws
This is exactly th problem I'm facing, similar washer. However, this solution doesn't seem to get the knob off the washer. any advice?
Old 04-05-09, 11:24 PM
F
Received 1 Upvote on 1 Post
the knob should just pull off.
Old 04-06-09, 04:27 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
either push in or pull out knob should not turn one direction and than screw off. If ratchet devise broken in timer may have to dissemble timer in machine and hold shaft. Never had that happen to me, Unplug machine first
