whirlpool washer agitate, fills but won't drain or spin
Hi all,
I have an older Whirlpool washer (model LSV7244AQ0 ) and apparently overloaded it with a lightweight matress cover -- not so light when wet! It unbalanced the machine and when I rebalanced it, it would agitate and fill but not spin or drain. I read some other threads but since I don't have a manual that shows the "lid switch" I"m not sure where that is and if it is working. The timer seems to be working because if I put it on spin, it doesn't spin but will tick down and start filling for a second rinse. I'm not particularyly mechanical but hate to spend money for someone to come and flip a swich or something if I can try myself.
Any help is appreciated
if the motor does not turn when you turn it to spin its most likely its the lid switch. part# 285671.
you can confirm this by removing the 2 screws in the bottom front of console so you can flip console upwards. then temporarily bypass the switch with a piece of wire
Thanks so much! I don't have any diagram to know which is the switch to try to bypass it. I found a picture on the web of the part, but is there somewhere to look to get a picture of where it goes? I can open the console and flip it back but I can't see a switch in my console that looks exactly like the part diagram....
Also, I just looked in the washer again and found a small (about 1-2 inch) piece of white plastic in there. I don't see any place it could have come from... but??
Thank you again.
Thank you again.
