whirlpool washer LXR9245EQ1
Old 04-30-09, 05:59 PM
F
Received 1 Vote on 1 Post
yes this is the same one i replaced the agitator on. this time i think the clutch went. when it goes into a spin cycle the agitator does not spin it makes a noise like something is slipping and grinding almost like its jammed. the bucket spins but not the agitator. any ideas.
Old 04-30-09, 09:14 PM
F
forgot to add. I removed the agitator and it still does it. the shaft does not turn. it acts like its jammed.
Old 05-01-09, 04:38 AM
first thing i would check is the motor coupler
Old 05-01-09, 05:17 AM
If the washer will not agitate or spin=bad coupler.
Old 05-01-09, 05:39 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Are you sure it spins? Did you open lid and see it spinning? If it is you most likely broke the gearcase. Reason I am asking is gearcase do not break very often usually drive coupler.
Old 05-01-09, 11:14 AM
F
yes i opened the lid. it grinds and makes a slipping noise. the basket spins but the agitator does not.removed the agitator same results.i don't think the new agitator caused it unless the gears were already weak from old age and the stress from a new agitator caused it to break.
Old 05-01-09, 03:35 PM
F
i looked up the gear case online. its 144 dollars. is it easy to replace or not worth it.
heres a short video. as you can see and here it spins but grinds and slips.machine is direct drive no belts.
http://img531.imageshack.us/img531/5162/pict0001gy1.flv
Old 05-01-09, 04:20 PM
put the video on youtube. couldnt view it
Old 05-01-09, 06:05 PM
F
try this (added this to comply with the min letter rule)
forget it the stupid forum is bleeping out tinypic dot com have to spell it out or the forum censors it. i'll try later.
Old 05-01-09, 09:17 PM
F
ok lets try this again. i used flicker
PICT0001 on Flickr - Photo Sharing!
and the agitator is spinning. as you can hear from the video its grinding and then it starts slipping.
Old 05-02-09, 04:39 AM
so that video was made in the spin direction?
does sound like stripped gears inside the gearcase
Old 05-02-09, 11:11 AM
F
correct. it was made during the spin cycle. is this a easy repair to replace the gear case.
Old 05-02-09, 04:46 PM
gearcase is easy
4 clips, 4 bolts and 2 screws are all that hold it in
Old 05-03-09, 03:46 PM
F
I removed 3 bolts and the trans slid forward about a inch and then stopped. it wants to take the motor with it(direct drive). there appear to be small hex head screws but there inside the motor and cannot be accessed. do you have a schematic for removing the transmission.
Old 05-03-09, 06:20 PM
pugsl's Avatar
Did you take off agitator? Take water pump off, leave hoses on, take 2 1/4 screws out of straps and take off straps, motor will come off. Gearcase should slide out. Sometimes soap build up on shaft and will have to be slid in and out a few times.
Old 05-03-09, 06:39 PM
F
ummmm lol that would help.
ok
now on the motor there's a large capacitor the size of a D cell battery. now i want to stay away from that right.
Old 05-03-09, 07:45 PM
no reason to mess with the capacitor
Old 05-04-09, 04:43 AM
pugsl's Avatar
Don't need to unplug wires just lay motor off to the side.
Old 05-05-09, 08:51 PM
F
i don't suppose the gear case can be rebuilt could it.
Old 05-05-09, 09:32 PM
pugsl's Avatar
It can be you used to be able to get parts from Sears but I just looked up your model # and did not find gearcase parts, Google them I know they are out there.
  #21
Old 05-06-09, 03:50 AM
you can get reman gearcases for $60 on ebay.
  #22
Old 05-07-09, 04:04 PM
F
  #23
Old 05-07-09, 07:28 PM
looks ok to me...........................
