JennAir Refrigerator Not cooling
Hello all, we have a JennAir side by side ref MODEL # jcd2389gtb and the refrigerator side is not cooling but the freezer still making ice. I thought that it might be the fan that blows cool air to the ref side from the freezer. Don't know if that's how it works. Also I noticed that the ice cubes are bit transparent not solid frost (am I making sense here.). Anyway, does any one experienced this problem before? What do you think is wrong with this refrigerator? I appreciate all your advices.
Thanks
Thanks
First thing- set the controls at the mid range of their settings. Next, check the coils under the fridge to see if they are clogged with dust, etc. Next, using a couple stem thermometers, determine the temps in the freezer and fresh food sections. In the fresh food section, place a tall glass of water on a shelf in the middle, put the thermometer in and let it set for awhile in the fridge. Inside the fresh food section, look for the damper opening at the top of the wall in between the two sections. Wet the back of your fingers- can you feel air blowing thru the damper opening? Inside the freezer section, look at the back wall- any frost buildup there?
No dust under the refrigerator coil, there's also little air coming in from the damper, I looked in the back of the freezer and there's a little frost build up in the back wall about mid section where the back panel protrude towards the front. I will do the thermometer thing when I get home. what temp should I expect?
freezer 0F to 5F
fresh food 38F to 40F
If you have a frost buildup on the back wall in the freezer section, you have probably found the problem. Remove the back wall panels to see if the freezing coil is frosted up. If you're not sure how to get it apart, go here for diagrams.
Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com
freezer 0F to 5F
Thx again for your kind response.
