Frigidaire FEF352ASE oven will not heat
Old 08-06-09, 03:18 PM
C
According to tenants, the stovetop is fine but the oven was working and no longer heats. Suggestions? Its 45 minutes away so I'd like to have an idea of what to look for.
Old 08-08-09, 01:46 PM
E
In case it is not fixed by now - could be burned out element if it only affects the bake element and not the broil element, and especially if you see a spot along the element that is blistered and has molten metal coming out of it.
But if both suddenly do not work, and someone knows for sure the broil element was working, and also has no external signs of blistering - then, often someone fiddled with a timed bake control knob in association with the clock, and it got off it's manual setting. If so, set it to 'manual', then see.
