Kenmore 90 Series Clothes Dryer will not start
Received 0 Votes
Heres the deal...
The wife was doing a load of laundry last night and when she went to start the dryer she said that when she pushed the start button the machine made a buzzing sound (i assume this is the end of cycle alert noise). she again pushed the button and didnt get the noise nor did the machine start. i checked it and it appears to be completely dead, when i push the start button there is no noise at all, nothing.
A few motnhs ago I replaced the heating coil and cleaned out the whole dryer, icluding the venting system.
I will be following the steps below to diagnose the problem, if anyone has any suggestions please let me know! when I figure out what the problem is/was I will add it to this post.
#1, Check the breaker box.
#2, Check the Start button
#3, Check all thermostats and cut-off switches, including the new coil i replaced a few months back.
#4, Check the ventilation and make sure its clear.
Fortunatley I have a Sears repair facility 2 blocks from my house so I will pull the start button and thermostat/cut-off switches and take them all over for testing.
Again, any suggestions are welcome, I will post the solution as soon as I find it!
Received 0 Votes
Update
The dryer has been working intermittently. The thing i really notice is when it is working, i push the start button and it doesnt immediatley start like normal. there is about 1/2 second where i have to hold the button down before it gets going. it reminds me of a car that needs to turn over a couple times before it will fire up. We were able to run a couple loads through before it quit working and now (a couple hours later) it is working again. It seems like a thermal issue, it stops after prolonged use, and after is cools down again its ready to go. I wish it would just quit so i could diagnose it better.
any thoughts anyone?
Received 0 Votes
Yes, it makes a "humming" noise, like its struggling to start turning. I am getting the impression that it is a motor issue. If/When it gets moving you can hear the machine struggling to keep going. I am going to pull the motor and have it tested. I will pass on the results as soon as i get it done.
Received 0 Votes
Similar issue w/ Kenmore series 90
I have a similar issue. 1st symptom was buzzing rather than starting. Replaced the motor with a new one. Now it doesn't start and there's no buzz.
Suggestions?
Suggestions?
Received 0 Votes
You didn't forget to check the circuit breaker or fuse, did you? As the buzzing is hard on the electrical draw and could have blown or tripped something right there, with the old one.
Or, you did not buger up the jack connector or motor terminals down by the motor by chance by say trying to force it on backwards or something, on the first reassembly attempt?
Other than that, if you have power to the recepticle and check the door swith and maybe console start switch......hmmm......you might want to try to throw the old motor back onto the the connections, temporarily, to see if you get that buzz once again. That way you would know whether or not your new motor is a bad one.
