Maytag Neptune: spastic motor
Received 0 Votes
I've got a Maytag Meptune model MAH4000AWW. When it starts to run the motor jerks back & forth instead of running smoothly. I found that the 3-pin plug for the rotation sensor on the back of the motor was loose, so I removed it and resoldered it, but that didn't make any difference. Any suggestions? I've heard there were some problems with the motor control board, but don't know if my symptoms fit... anyway, hoping this is a known problem and someone can tell me what to replace.
Thanks,
-Dave
Thanks,
-Dave
Received 0 Votes
Yeah, I checked the spec sheet but none of the tests really apply. Are most of the problems fixed by the replacement parts (eg. motor control board, machine control board) or are they just new boards with the same problems?
It's quite a nice machine - smooth, quiet - so if I can invest a couple hundred dollars and have a reliable washer then I'll do it. Better than buying a new one for $500+.
You might fix one problem but you will have another one soon. Washer is junk. Motor control board comes with a motor, next problem is with main control board and wax motor, Next comes the bearing being bad, I would not use that machine for a boat anchor.
Received 0 Votes
OK, I tried the Drive System diagnostic test, and the motor did NOT spin at 50 rpm: instead it did the same thing it's been doing, namely made clicking noises and jerked back & forth. Does this mean I definitely need a new motor & board assembly, or is there something else that could be causing this (eg. the motor rotation sensor)?
The other thing I noticed: When it's in delay mode, the hot water valve opens and it starts to fill. If I leave it it'll continue filling indefinitely, until water runs out on the floor. I don't think this is a valve problem, as the valve shouldn't have power going to it in delay mode anyway. What else could cause this? (Yes, I know a faulty machine control board, but I'm hoping it's not that. Both the machine board and wax cylinder were replaced about 5 years ago by the previous owner.)
I'm going to start looking at new units, but want to make one last attempt to save this one!
-Dave
-Dave
Received 0 Votes
as far as top loaders the LAT model top loader is well built, and the newer direct drive ones that are made by whirlpool.
the only maytag front loader worth a crap is the one made in germany by whirlpool.
All the Neptunes are junk, The LAT model were the last of the good ones, Quit making them 10 to 15 years ago. Whrilpool bought them out a couple of years ago and now they are expensive Whrilpools
