Whirlpool Front-load washer won't turn on
Received 0 Votes
Hey all,
I have a Whirlpool Duet HT washing machine (GHW9100LW2) that has been working just fine. My wife went to wash a load of clothes, and the unit has no power. She checked the breaker, and verified that the outlet was working, but there's either no juice going to it, or the little hold and turn on button has gone kaput. Any ideas?
Thanks,
Steve
Thanks,
Steve
Received 0 Votes
I suggest you contact a professional first before doing any diy. I've experience a problem with my frig before and tried to fixed it myself without consulting a technician. I ended up buying a new one.
Take off the lower front panel there is a tech sheet there, Either in panel or on the side of washer, Start there. !st before check voltage at the outlet. Check for both polarity and 120 volts.
Received 0 Votes
The manual inside says if you don't hear the CCU click when you plug it in, then it's toast. There's no click. All of the connections look good and clean. I have one of those cheap outlet testers and it said the outlet was OK. Plugged a vacuum in it and it worked OK as well. I have a multi-tester, but have never used it on a wall outlet. Should i use that to check the outlet before i go looking for a CCU?
Received 0 Votes
