Kitchenaid KER1203 Fan Noise
Old 01-14-10, 05:18 PM
The fan on my convection oven is hitting the shroud. What is the solution?
Old 01-18-10, 08:35 PM
You can remove the cover and gently bend the fan so it isn't wobbling. Otherwise you would need to replace the fan blade.
Old 01-19-10, 03:13 PM
With any fanblade application where dust or out of balance or centering may be the issue, if it were me, I would gently clean each blade so all are uniform. Then without altering the blades, I'd twist on the motor itself so that the blade winds up as centered as possible. Bending blades, unless of course they already got bent, can cause them to wind up out of balance.
