Frigidaire Ice Maker not working
I have a model FRT26XHAD1 Frigidaire refrigerator about a year ago the ice maker stop working. The ice maker has no water in it however it still continues to serve water from the door drinking dispenser but with low pressure. I have shut down the refrigerator for cleaning for a few hours I was also hoping maybe this was a frozen line to the ice maker but it was not. Could my saddle valve be clogging that would be causing this condition?
Thanks for all your help
Sam Connor
Sam Connor
This an older icemaker assy (non-electronic control)
I would replace the icemaker and the dual water valve assy.
As long as the saddle valve is mounted to the cold water source---on the top or sides of the pipe---it should be fine.
Saddle valves that are installed at the 6 o'clock position are prone to clogging by debris/sediment.
