Thermal Fuse Issues-dryer wont turn on
Old 02-08-10, 10:04 PM
i have a magic chef dryer model no. CYE3004AYW. I have tested the thermal fuse with a multimeter for continuity and found the thermal fuse to be bad (open). I bypassed the t.f. and dryer turned on. Are there reasons for the t.f. for going bad? The dryer/washer are only 5 years old and were a gift. Is this beginning of more problems?
any advice would be greatly appreciated!!
Old 02-09-10, 03:11 AM
pugsl's Avatar
Received 13 Votes on 13 Posts
Thermo fuse bows because to much heat. Usual reason for to muh heat is a clogged vent to the outside. Check vent behind dryer and make sure it's not crushed there first.
Old 02-09-10, 09:10 PM
Will do. Thanks alot.
I'll keep ya posted.
Old 02-10-10, 04:28 AM
heater element shorted to ground will do it too. make sure dryer doesnt heat when set to air dry....
