KENMORE HE2 Plus Washer
Old 05-24-10, 07:02 PM
I have an approx. 3-year old HE2 Plus Model 11047512601.
The "Start" switch only works intermittently.
Is there a way to determine what needs to be replaced if anything?
I'm guessing either the Control Panel or the Electronic Control needs to be replaced?
Any suggestions?
Thank you.
Old 05-25-10, 03:34 AM
pugsl's Avatar
Received 70 Votes on 63 Posts
Could be user interface, what dose it not do, lights won't come on, won't run?
Old 05-25-10, 12:50 PM
Correct; the lights don't go on and the washer does not run.
Old 05-26-10, 03:20 AM
pugsl's Avatar
Start at beginning, is there power to washer? open bottom panel and get tech sheet, Where is a test procedure to follow. hate to see you put 100 to200 in a user interface without doing the checks.
Old 05-26-10, 04:54 AM
If I push the "Start" button enough, or when I apply pressure to the control board, the washing machine will turn on.
I'll look for the Tech Sheet, follow the test procedure and see if I can determine what the problem is.
Thanks!
Old 05-27-10, 03:02 AM
pugsl's Avatar
Sounds like user interface to me but do the checks
