GE Dryer squeaking noise?
Old 07-11-10, 08:45 AM
We've had this front load dryer for 2 years or so and since a month now it started with a slight a squeaking noise but getting louder, any ideas please?
Old 07-11-10, 12:09 PM
pugsl's Avatar
Upvotes Received: 13
post model # take front off and make sure plastic bearings are there and in good shape. Dose the noise sound like it's coming from front or back? UNPLUG DRYER BEFORE WORKING ON IT
Old 07-12-10, 07:52 AM
Model # is DHD5R46GEOWW.
I don't understand what you mean by "take front off" since it's a front loading machine meaning the door is located on the front of the unit? The noise seems to be coming more form the front of the unit like just behind the door?
Old 07-12-10, 06:17 PM
pugsl's Avatar
PleASE RECHECK MODEL # DID NOT WORK. Open door in top of opening 2 screws, remove screws and top will slide to front and than tilt up and off( sometimes very tricky) look inside there should be 2 screws 1 on each side holding front on. don't disconnect wires unless you mark them, You should be able to see the plastic bearing now.
Old 07-14-10, 07:03 AM
Sorry about the wrong model number, here's the correct number DHDSR46GEOWW
Old 07-14-10, 05:11 PM
pugsl's Avatar
http://www.searspartsdirect.com/part...4090032&blt=06 here is a link to your dryer 313 or 316 is what I am guessing you need
Old 07-14-10, 05:25 PM
Yes, that is it, lately what I am noticing is that the squeaking noise is mainly at the startup of a cycle and dissapears after a while.
Old 07-14-10, 05:48 PM
pugsl's Avatar
may be the belt or idler pulley but not very common.
