kenmore freezer works frig doesn't
Old 09-03-10, 02:38 PM
B
i have a kenmore refrigerator model # 253 74834400 the freezer section is working fine but the refrigerator section is not working at all. there is a build up of ice in the back of the freezer compartment. i can also here the fan running in the freezer.
Old 09-03-10, 06:32 PM
E
It is probably froze up because a defrost timer (mounts usually up on the ceiling of the fridge section next to the temp control on later models and on real early models mounted to the chasis behind bottom grill, or at rear) or defrost stat (clamps onto the cold coils in the freezer) failed. Each are very DIY-able if you are at all handy. Each can be tested independently.
Old 09-03-10, 09:06 PM
B
defrosted the ice in the back of the freezer refig seems to be getting a little cooler but not cool enough.can you give me some suggestions on testing.
thank you
Old 09-04-10, 04:53 PM
E
Was the fridge running for say at least 1/2 hour straight before making the assessment that it is stil not cooling as good as it should?
Keep in mind that the cooling coils in the freezer are capable of way below 0F. But when the freezer has been defrosted and is now at room temperature inside it, the room temjperature air is being drawn across the freezer coils and blending the temperature. It will take awhile for the freezer temp to come down. If say it still has not come down to near normal cold temps by an hour or so, then either it went into defrost mode on you (if the compressor shut off), which will throw you a curve ball, or you then likely have a major issue like a freon leak or bad compressor, IF the compressor has been running steady without stopping, and still is not sufficiently cooling.
