Estate Dryer Timer problem?
Old 11-01-10, 05:43 PM
A
I am helping a neighbor with their estate dryer (TED8840PQ0) It is having problems running. It will only run while putting pressure on the timer dial. If you let go it will only for a few seconds and then the buzzer goes off and the dryer stops. After messing with it for a few minutes you can get it to run for up to 5 minutes before it buzzes again and stops.
I am assuming that it is the timer going bad but want a second opinion before I have them pick one up.
Thanks
Old 11-02-10, 04:32 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Model # did not work. It sounds like timer,
Old 11-02-10, 03:44 PM
A
So I can't read..
Model TEDS840PQ0
Will try a timer and see what happens
Thanks
