GE Potscrubber 600 DW problem
Old 11-04-10, 09:00 AM
T
First of all thank you for reading and any advice.
I have a GE Potscrubber 600 at least 21 plus yrs old. It has been a workhorse although quite noisy but I suppose that is typical for a mdl that age. It is to be replaced when I do my kitchen overhaul in the spring.
This is the problem. I normally use the normal wash/light cycle setting with energy saver(no heating dry). However, I notice the last several washes that mdl will not go into final drying cycle(without heating element) as it usually does. The control knob just stops so I rotate it into off position.
Could this be a defective control knob that needs replacing or is there something more at work here?
I hope I have explained the problem clearly.
Thank you again.
Old 11-05-10, 01:47 PM
T
gosh.
is my post unclear?
what about it appliance pros?
thx
Old 11-05-10, 04:55 PM
E
Since there are no safety items to keep it from advancing, and since it stops advancing, I'd say that you unfortunately have something wrong in the timer, unless you can clearly tell the knob itself is hanging up on something.
