kenmore 110.23832100 washer
Old 11-22-10, 08:13 PM
H
My kenmore 110.23832100 washer will not agitate or spin. It has had a hard time spinning for a while....I replaced the coupler thinking that was the problem and after opening it up found the original coupler was OK. I replaced it anyway and the washer worked for 2 loads with no change in the spin problem. After 2 loads the washer will only fill up and drain. It sounds like the motor or transmission is trying to turn the agitator, but it doesn't move. I tried replacing the clutch since then and after reassembling the washer nothing changed. Does anyone have a solution out there besides buying a new washer? I fear the transmission is shot..... There was oil on the floor beneath the motor and a little slung on the inside of the outer body of the washer... HELP!
Old 11-22-10, 08:19 PM
Tolyn Ironhand's Avatar
Received 218 Votes on 193 Posts
This thread bight be of interest: http://forum.doityourself.com/kitche...same-time.html
Old 11-23-10, 12:07 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
I think you need a gearcase. Google whirlpool gearcase there is a video showing tear down and repair.
