Go Back  DoItYourself.com Community Forums > Household Cleaning, Kitchen Appliance Service and Repairs > >Electric< Large Kitchen and Home Appliances
Reload this Page >
Kenmore 70 top Load washer completely stuck Motor makes electrical hum noise
Old 12-08-10, 03:02 PM
R
Hi, I found the circuit breaker tripped to laundry room. So I turned off washer which had 1/4 tub filled with water, reset breaker and tried starting washer. Only result was a dimming of light bulb in room and loud hum from washer, probably motor.
Next, I removed all items from tub inclufding several that were wrapped up real tightly around agitater. Could now turn agitater. Tried restarting in any cycle position same thing, loud electric hum.
Will be looking at it more closely tonight, appreciate any tips.
TIA,
Ross
Old 12-08-10, 04:04 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Most likely a sock stuck in water pump, Usually can't get sock out and need a pump, Easy to check. Take cabinet off, Unsnap water pump from motor. try to run in wash and see if motor runs. If it dose you need a pump. DO NOT TRY TO TAKE OFF BACK
Old 12-09-10, 09:44 AM
R
HI and thanks for the feedback. I did just that last night and found ladies panties in the waterpump. fortunately, they came out easily.
I was impressed with how easier the newer generation of direct drive washers are to service. Maybe that's because they are mostly all made in the orient now.
