Kenmore 110 series electric dryer
My dryer shuts down every 10mins no heat no nothing but starts right back up when started. I just replaced the belt and pulley system on it last weekend thought that might fix the problem
Any help
Any help
Not a common problem. Do you have to turn timer? Make sure the door is closing tight, Have seen where the clothes bump door and open switch, Possible loose wire at terminal block at back of dryer. Before you check that unplug dryer.
Very unusual problem, most times when dryers stop after running it's the motor but it would not restart until after a cool down period usually a hour or so. most parts on dryer either work or not very seldom intermittent.
Thanks
I wish I had the money to just get new one, I don't so I got to fix it !!!! I might need to get someone to look at it but they will charge out the %#$^ to fix it
