amana front loader washer no spin
Old 01-15-11, 09:27 AM
Doorman2722's Avatar
Received 37 Upvotes on 37 Posts
I have an Amana Front Load Washer #NFW7200TW that will not spin intermittently, I ran all diagnosis in trouble shooting guide that came with the machine, and receive no error codes. I suspect a faulty C/B. Are there any commom causes for not spinning. Door is shut and locked, motor is good because it does rotate back and forth during wash cycle and it spins when it wants to. Pump seems to be working fine and does pomp water out. If I put it spin only, some times it spins, and some times it just sits there. I did re-seat all correctors plugged into the circuit board, It spun for several tries but now is not spinning. Thanks
Old 01-16-11, 05:13 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Your washer looks like it was built by Frigidaire. What usually goes bad with them is the door lock. Will agitate and not spin. Have never seen one with a Amana name on it.
Old 01-16-11, 08:06 AM
Thanks for the reply, I am pretty sure the door is locked because i can't open it and the lock indicator is lite up, but I will look and see if it can be adjusted any
Old 01-16-11, 03:34 PM
pugsl's Avatar
No adjustment needs to be replaced.
