Water accumulated at the bottom of dishwasher
Old 01-17-11, 01:12 PM
H
I have a dishwasher (model: Whirlpool DU929PFGB2). It drains well, but when I use the disposal, the water gets fed into the dishwasher. Do I need to replace some part so that water from the disposal stays in the drain pipe only, but not getting inside the dishwasher?
Thank you for your reply!
Old 01-19-11, 06:58 AM
A
harjotw,
Start here
Check for a restriction in the pump and drain hose.
Check for kinks in the drain hose itself.
Likely issue could be the piston valve.
Old 01-19-11, 07:21 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Is there a loop in the hose from the disposal up and higher than the dishwasher? You need that or an air gap installed (some codes require it) in order to keep water from puking into your dishwasher.
Old 01-21-11, 11:24 AM
H
There is no hose loop. I raised the hose under the sink higher than the disposal, and no water going back to the dishwasher now. I googled this and then looked at the air gap option, but there is no hole on the sink to install it unless I can find a tool to make a hole on the steel sink.
Old 01-22-11, 06:02 AM
chandler's Avatar
Unless local code calls for it, I wouldn't go to the trouble of trying to drill stainless steel what a bear! It appears attaching the hose in a loop solved your problem, so it ain't broke......enjoy.
