Maytag Dependable Care Top Loader Washer
Old 03-02-11, 04:41 PM
D
My Maytag Washer spins while in the wash cycle thereby throwing water out of the tub onto the floor. I believe there is a problem with the agitator, althought the agitator seems to be functioning.
Old 03-03-11, 03:22 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Need model # , Couple of quick things I can think of 1 Pulley assy. under washer needs lube 2 transmission bad.
Old 03-03-11, 09:16 AM
D
Model # Maytag LAT9416AAE. If I put downward pressure on the agitator, it stops the spinning and the washer works normally. I was thinking, maybe the clutch.
Old 03-03-11, 02:27 PM
pugsl's Avatar
That a old one have never taken that clutch assy apart. Sounds like that is your problem.
