Kenmore 500 Washer Will Not Drain!
Hey I have a Kenmore 500 top load washer and for some reason the white spinny thing in the middle is sucking up clothes underneath it. This I believe is causing it to not drain properly. Any help or ideas would be helpful including how much it would cost if I had to have it repaired professionally.
Not draining is usually the lid switch. Clothes under agitator may be the drive block is wearing out. Can you put your fingers undere the agitator? sho0uld be able to only get tips of fingers under it. most repairs between 150 to 250
