Help! my Frigidaire Oven is Locked..
Received 0 Votes
My Self cleaning Oven 'Frigidaire' with ceramic top- 5 years old -is Locked ..
We did not lock it .,,, IF we did a Clean ( by pressing the button) it will lock the door and the time will display 3 Hours and the oven will come on and proceed to Heat up and clean ..
We just approached the Oven today and found the lite lit up LOC and the door closed and no matter what we press on the front panel it will not Unlock.
So I turned off ( for twenty odd seconds) the switch in the electric panel box and reset the switch back to on and it still says LOC .
I can't find the exact model number as it is on a label on the inside of the stove when you open the front door to expose the racks inside ..
Help Can you help me to figure out how to UNLOCK .. ?
Thanks
Thanks
Received 0 Votes
actually none of the buttons worked and was fully locked .. BUT after a ten minutes of no power from the circuit breaker I was finally able to reactivate stove wit hthe LOC off and was ablew to get the stove back to ' hopefully' normal .. IT had an F90 warning during this process .....
