Kenmore Model 110 Washer won't spin - not the lid switch
Old 07-17-11, 12:45 PM
My Kenmore model 110 top load washer stopped spinning on the final cycle. However, if I push on the "Wash Action" selector button, it starts spinning. Do I need to replace the Wash Action switch?
Old 07-18-11, 04:34 AM
pugsl's Avatar
Received 75 Votes on 68 Posts
Post MODEL # NEED TO SEE WHAT SWITCH YOU ARE TALKING ABOUT. Most Kenmore washer start with 110. Does this washer have a touch panel?
Old 07-18-11, 09:15 PM
No touch panel, it's probably 12 years old. Full model number is 11092588810.
Old 07-19-11, 04:44 AM
pugsl's Avatar
Model # did not work put I think you have one that has 4 knobs and timer on panel. I think you are talking about speed control switch usually has about 5 or 6 positions on it. 1st open console 2 screws under 2 plastic covers on front sides of console. take scre3ws out and lift and pull to you.It will hinge up and over. Make sure the wires are plugged in good. If they are you most likely need a switch.
Old 07-19-11, 10:50 PM
That is what I figured. Thank you for your help!
Old 07-23-11, 10:52 AM
Now I am trying to figure out how to remove the speed control switch. I cannot see what is holding it in place. Do I need to remove all of the knobs from the front panel to get the mounting board loose?
Old 07-23-11, 02:16 PM
FINALLY! If anyone needs to replace one of the control switches on a Kenmore washer, simply remove the two screws holding the control panel to the washer and flip it up. Remove the knob from the front and the wire harness from the back of the switch, and then, while prying back the locking tab on the top of the switch, turn the switch 1/4 turn counter-clockwise. It pops right out!
