kenmore 80 series dryer issue
Old 07-18-11, 04:45 PM
R
last week i diagnosed my dryer to have a bad motor due to a bad start winding. so i replaced the motor on friday, tested out ok. sunday i use it. ran for about 15 seconds and shut off, turned it on again, same thing. tried again, dryer ran good until i opened the door. then i tried to start it one more time. the motor runs as long as the start button is pushed in, but as soon as i let go it shuts off. the only thing i can think off is the motor's centrifugal switch is not clicking over making the neutral side switch contacts and bypass the push button start. can i really have another bad motor right out of the box? i didnt get a chance to amp the motor and make sure it wasnt over amping. i wanted to check this because i was wondering why the start winding went when its only in the circuit for two seconds and i'm hoping the motor isnt over amping causing the start winding to go.
Old 07-18-11, 04:50 PM
R
Old 07-18-11, 04:53 PM
R
Old 07-18-11, 04:55 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Post model # need to see what dryer you have.
Old 07-18-11, 04:56 PM
R
model number is 11072852100
Old 07-18-11, 05:30 PM
pugsl's Avatar
You are right, there is no motor relay on that one. Was it a new motor? Switch is in motor. dryer motors almost always have start winding go bad when motor goes. Very unusual motor go bad out of box.
Old 07-18-11, 06:40 PM
R
yup brand new motor. got it from partsselect.com also threw a new belt on there. i guess i need a new motor. AGAIN!!
