GE Profile dishwasher - no water
Hi all-
I have a GE Profile dishwasher. Model # PDW8200N00BB. Serial # HM865817B
When I start the dishwasher, the dishwasher sounds like it is going through its cycles, the metal heater coil along the bottom of the dishwasher gets very hot, and the soap drops in to the dishwasher. It also sounds like there is noise coming from the dishwasher, which I assume is the pump running. However, there is no water.
To add a wrinkle, we just came back from a 10 day vacation and this is the first time we have run the dishwasher since returning. Before we leave for vacation, we shut off the water to the house and drained all the water from the pipes by opening the downstairs bathroom faucets.
I am relatively handy but know nothing about dishwashers. Where should I start with this? I am guessing an airlock or some sort of valve that "dried out" and got stuck? I have no idea.
Thanks!
Thanks!
I would look at the line from the valve to where it hooks to the dishwasher. Some are of a flood safe design and turn the water off automatically.
Check if you have flood safe here. There are also the reset procedure. If you dont have post back.
FloodSafe® Automatic Water Shutoff Connectors - New Products - Watts
Mike NJ
Mike NJ
Mike NJ
Mike NJ
Wow, that's a really cool water connector. I'm going to have to get some of those!
But no, we don't have them. Also, I shut the water off to the house probably 3 or 4 times a year and it hasn't been a problem before.
While I have been waiting for replies, I took the kick plate off just to take a peek underneath to check for leaks and such. No leaks and the pump seems to be operating.
Wee you dont want those hoses trust me.
Next since you have the kick plate off, turn off the water. Disconnect the line at the washer and stick in a bucket. Turn on valve to see if you have water.
If you have water the best I can say is shut the power to the DW. If may reset the elcetronics.
Do you here the seloniod clicking?
Mike NJ
Mike NJ
Mike NJ
Mike NJ
I called a repair person and he is coming tomorrow. I think I'm just going to have to eat the $90 service call this time. Thanks for trying though.
Received 0 Votes
I have found that if a dishwasher sits for a while it dont matter what make, it needs to be primed. Dump a pitcher full of water into the bottom of the dishwasher and try starting it. It has worked for me everytime I have done it. I can't explain why but it works.
EDIT: wait, maybe not. When I put a couple of pitchers of water in, the dishwasher runs for a while with water and then it runs dry. Something else must be going on
Received 0 Votes
hmmm then it sounds like it is stuck in the drain mode. When you first start it does it drain right away? Then continusly make that sound as if it is draining? Kind of a wah ahhhhh ahhhhh ahhhh sound? If it does, then it is the selinoid, it is stuck and not closing the drain. Usually the Priming it with water always does the trick for me..
Well, that's the way it goes. I don't know how to replace it myself.
I haven't had much luck with GE appliances. This one is only 4 years old.
He, he. Now it's working fine. I also played with the float in the dishwasher pan along with some more pitchers of water, and now it appears to be working. Anyway, thanks for your help. Hopefully it will keep working!
