Kenmore washer mdl 110.26962503, full of water, stopped
Old 09-02-11, 08:54 PM
The washer filled with water and stopped. No noise, tried every setting on machine, unplugging the power...nothing. How do I remove water if necessary for any repair recommendations? Any ideas or help would be appreciated! Thanks!
Old 09-03-11, 05:01 AM
pugsl's Avatar
Received 25 Votes on 24 Posts
Tighten the screws to the left side hinge. Lid switch is there and screws come loose and washer will not work.
Old 09-03-11, 08:21 AM
Thanks, but I failed to post that I had tired that. Any other suggestions?
Old 09-03-11, 05:04 PM
pugsl's Avatar
Open console and jump lid switch, Two wires not colored green and put in spin. if spins you need a lid switch (not common) Make sure you have power to washer, Plug a light in if you don't have a volt meter. Last thing I can thin k of is to take off cabinet and wiggle white wire to motor. It's the neutral and if loose will not run. Need help on how to open console or take cabinet off let me know. do not take anything off back not how it's opened
