Washing Machine starts, fills up, spins & then stops - won't drain
Old 10-02-11, 01:36 PM
Hello,
My 7-yr old washing machine will start, fill-up with H20, spin and then when it is time to move to the next cycle it completely stops and will not drain. If I manually remove the water myself, it will restart and do the same thing, but it won't drain and it doesn't matter if I move to a different cycle e.g. spin, drain, etc. it won't do a thing.
I am single-girl-with-house and I am wondering if it is better to just get a new washing machine or call someone in. My fear is that calling someone in will cost almost as much as buying a new one and/or it will be fixed and I will continue to have problems. This is the 1st time anything has gone wrong with it.
Thank you, Mimi
Old 10-03-11, 05:14 AM
pugsl's Avatar
Received 75 Votes on 68 Posts
Need type and model #. I would guess lid switch
Old 10-12-11, 10:16 PM
Hello...it is a Kenmore 80 Series
Old 10-13-11, 01:54 AM
pugsl's Avatar
Kenmore 80 series doesn't tell me anything open lid in back is a tag with model # need that.
Old 10-20-11, 04:13 AM
hi i was trying to do a load of laundrey today and my washer filled up and ajitates sorry spelling is bad but anyways it wont drain, and it dosnt make a noice and the lid switch is just fine, so im askin if someone could help me out and reply back? ill give the model number and all that 2marrow. thank you.
Old 10-20-11, 02:53 PM
pugsl's Avatar
Classic symptom of a bad lid switch
Old 10-21-11, 12:06 PM
Hello - the "MOD is 110.25902400" (I hope this is it) Thank you, M~
Old 10-21-11, 03:28 PM
pugsl's Avatar
You are in the right spot but model# did not work Please recheck. the 110 means it's built by Whrilpool. Here is what is usually wrong.
To check lid switch. Find slot in top under lid. Put hand under switch and lift up. Use a pen or small screwdriver and push down on lever with washer in spin. turn on and if washer spins you need a lid switch.
Old 10-30-11, 02:10 PM
This is what I see:
Type: 111
MOD: 110. (in small type) then 25902400
SER: CR4003577
Does that information make a difference? Thank you again! M~
Old 10-30-11, 04:18 PM
pugsl's Avatar
Model # still did not work. Did you try to test lid switch like I said? Work on these every day and if it agitates and does not spin I always check lid switch first. 99 % the problem
Old 11-05-11, 03:27 PM
I will try tonight and let you know! Thnx for response! M~
Old 11-29-11, 07:52 PM
Same problem
My Model Number is 110.23032100. I have reached under the lid and messed with the switch. I plugged it back in and put the setting back on rinse and that fixed the problem.......for now? Is there something I need to plan on replacing?
Thanks for the help.
Old 11-30-11, 04:21 AM
pugsl's Avatar
You will need to replace the switch. Most likely won't work next time.
Old 01-08-12, 03:14 PM
Similar issue
I also have a 10 yr old Kenmore washer & dryer set. My washer has had some problems lately. Some loads start out fine and when it is changing cycles there is a thud and then nothing. Could that be a switch? Do you think it's just old and needs replaced? If so, I think this is a good excuse to get a front load washer and dryer. After all, we have 4 kids and use it every day.
Old 01-08-12, 04:44 PM
pugsl's Avatar
Need model # to help better. You may have a lid switch going bad read down few post to see how to check. Replace washer only if you really want a new one, I like yours better,
