Whirlpool Cabrio Automatic Washer (unbalanced)
Old 11-25-11, 09:07 AM
D
Please help me! If any one can. My problem is my washer. When it is in spin cycle it becomes unbalanced and stops, even when I redistribute the load. This happens even if it is a small load or nothing in it. Can anyone help!
Old 11-26-11, 03:29 AM
pugsl's Avatar
Received 71 Votes on 64 Posts
please post model# they have had software issues if the washer I am thinking of. How old is washer? does it show any F** codes
Old 11-26-11, 11:27 AM
D
Cabrio Washer Model # wtw6600sw2
I bought the washer in 2006. The only code I get is "ul".
Old 11-26-11, 12:07 PM
chandler's Avatar
Received 5 Votes on 5 Posts
That's "unbalanced load". I have one of the top loaders (to replace my Maytag Neptune, rip) and I find when doing larger items if it stops and displays UL, just pick up the items and let them drop in a neat pile in the middle. They will redistribute themselves pretty good from that point.
Hang in there for Pugsl, as he will have info based on the model number.
Old 11-26-11, 03:34 PM
pugsl's Avatar
Call Whrilpool and give model # and serial # I think there is a replacement control board for your washer. Serial # is important as they know which ones they have to replace by it.
Old 12-10-11, 05:41 AM
D
Whirlpool Cabrio Washer
Can anyone tell me how to remove the basket assembly! I have taken the agitator off and the retaining hub, also the top plastic ring, but the tub won't come out. Can anyone help? thanks!
Old 12-10-11, 04:52 PM
pugsl's Avatar
The tub just pulls out. If stuck I have had to drive the shaft out while another person lifts up on basket. If you do that you will need a new tub assy. Most times if they are stuck we order a new basket and tub. Look in owners manual I think tub is warranty for 10 years.
Old 12-10-11, 07:25 PM
D
Question Whirlpool Cabrio Washer Tub
Hey there Pugsi !
I got the tub out ok. But I found out why it gets unbalanced so easy. There is water inside the bottom of the tub! But I can't find out how it got in there. I have turned it every way but loose, but no water comes out. Any suggestions on how to get it out? There are no openings in the bottom of the tub at all!
Thanks!
Old 12-11-11, 08:37 AM
pugsl's Avatar
In tub or basket. Tub will have a little water near drain. Basket will have a water sound from balance ring (normal). Did you call Whrilpool about warranty or recall? Look at shaft in tub if there is a ring of rust on it the tub will need to be replaced, When you call Whrilpool tell them it makes noise in spin cycle. (loud Roaring) Should be warranty idem. Look in owners manual for warranty info. 1st page usually
