Kenmore dryer
Old 02-02-12, 06:30 PM
K
Kenmore dryer
The thermal cutout failed on dryer.I relaced it and the thermost that came with it.It worked fine for 2 days then failed again.Anyone have any ideas?
Old 02-03-12, 04:49 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Clean the vent to the outside. That is the most common start to ALL Dryer problems. Clogged vent causes the dryer to overheat
Old 02-03-12, 09:10 AM
K
I looked at that it is clear
Old 02-03-12, 12:14 PM
pugsl's Avatar
Is it a long vent or a short one on a outside wall? post model # so can see which dryer you have.
Old 02-04-12, 12:30 PM
K
The mod. No. is 110 . C60922990 Is there some way I can monitor the element housing temp. while the dryer is in full operation?
Old 02-04-12, 02:16 PM
pugsl's Avatar
Exhaust temp should be between 150 to 165 usually 160 to 165. Use a meat thermometer or something like it. IO have a electronic meter with a wire probe. Take temp with vent tube off and on. If temp changes more than 15 degrees Vent problem.
