Go Back  DoItYourself.com Community Forums > Household Cleaning, Kitchen Appliance Service and Repairs > >Electric< Large Kitchen and Home Appliances
Reload this Page >
Whirlpool washer Ultimate Care II Model # LSN2000PG1 fills with water then stops
Old 03-01-12, 02:53 PM
I
Whirlpool washer Ultimate Care II Model # LSN2000PG1 fills with water then stops and does nothing. No noise, nothing. It does not agitate, or spin.
Old 03-01-12, 08:31 PM
E
This could be for any number of reasons. I'm not familiar with the model but I'd check to see if theirs a lid connection first, that drops down into a small slot to see if it's making a proper connection. I think it's called a pressure switch but don't hold me to that, lol. Once found (if it has one), using a small screw driver, push and hold down on the lever piece inside. This should kick the washer into the next stage of agitation. If it doesn't, then that's probably where the problem is. If it does, then it might be the timer is faulty.
Old 03-02-12, 04:41 AM
pugsl's Avatar
Received 75 Votes on 68 Posts
Tighten the lid screws on the left side. Lid switch is under there and loose screws will cause your problem.
Old 03-13-12, 09:56 AM
I
Thank you for your replies...! Sadly, hubby has the washer apart. He says it is not the lid switch... he thinks maybe the motor seized up? How would he check that? Thank you in advance...!
Old 03-13-12, 03:23 PM
pugsl's Avatar
Cabinet off I hope, Nothing else? Jump lid switch 2 wires not colored green, wiggle wires at motor have found white wire loose and bad connection. If problem you have to find a way to tighten connection.
