Kenmore Freezer quit
I have a kenmore Heavy Duty model #25329111990. It has a high temp alarm that works! But yesterday, we noticed a puddle under it. Today, i checked the temp. 40 degrees with no alarm. The compressor doesn't even kick on. It does not have a self defrosting. It had slight ice buildup on the interior coils, nothing bad. But it just up and quit working. I am thinking it may be the thermosat, but if it is, any ideas on where i can get one? Looked at Sear's online, the part it no longer available.
If the temp control is bad it can be bypassed to prove that. If it is a two wire system you just hook the wires together and plug it in then it will start to run if the temp control was bad. If that starts it you can replace the temp control with a universal stat. Part number is cc-1 most parts places stock it.
