Stacked Kenmore Washer/Dryer - how to move them
Received 0 Votes
Hi All,
We have a stacked Kenmore washer/dryer in a closet, but there is a good chunk of space to the side that I want to utilize (home security alarm, home computer server, etc). The problem is that there is no way to access that space with the washer/dryer in their location.
I'd like to be able to slide them out of their closet when needed. Is there something that can aid in this? I'm imagining a sort of dolly and lift that I can keep in place under the washer/dryer.
The items I want to stick in there would not need to be accessed very much, just a few times a year (hopefully). Still, I'd like to be able to get in there quickly if need be.
Thanks in advance!
Thanks in advance!
Received 0 Votes
Yes, it is a front-loading washing machine.
I understand it needs to be firmly on the ground, but it still seems like something should exist that would allow me to move them periodically. And when I say move, I mean simply sliding out of the closet to be able to walk into it, and then sliding them back into the closet when I'm done.
The dead space in that closet is killing me!
Washing machines aren't portable appliances. As Don said, they must be firmly in place. They are heavy and can't be made to "slide". What kind of flooring do you have? Tile, lino? what type flooring on the room outside the closet?
Received 0 Votes
The floors are hardwood, or at least engineered hardwood.
I'm not disagreeing that the washer shouldn't be firmly on the ground, I'm just looking for some way to make use of the dead space in a 900sq.ft. condo where every inch counts. Like I mentioned, the dead space is perfectly sized for a home alarm box, as well as a computer server. In order to get these things in there, as well as maintain them, I would need to be able to slide the washer/dryer into the hallway occasionally.
I appreciate the responses so far.
You could engineer a substantial base with rollers that would run on a rail fastened to the floor. This base would then require jackscrews and (probably) a worm gear drive to a front-mounted crank of some sort that would lower the jackscrews to slightly lift the base up from the track and make it solid to the floor. Probably cost as much, or more, as the W/D combo unit.
