Maytag top-loader won't spin
Old 09-30-12, 09:39 AM
Cool Maytag top-loader won't spin
hey everyone,
i have a maytag washer (lat9306aae model) that won't spin. i recently replaced the tub seals and bearings to fix a leaking problem. this worked great, but the inner tub won't spin any more. the agitator works perfectly fine, but when it goes into any spin cycle, there's a loud squeeking noise, and the transmission isn't spinning. the belts are moving on the bottom, but the belt that connects to the transmission doesn't seem to be turning the transmission.
any thoughts as to what's going on? i think there may be something preventing the transmission from spinning, but before the repair, the inner tub span perfectly fine. i did have to break a bit of the transmission jacket i replaced in order for the grooves to be exposed as it wouldn't go completely down the shaft.
Old 10-01-12, 02:20 AM
pugsl's Avatar
Upvotes Received: 13
Possible 2 problems first is the brake assy is sticking # 5 in diagram
http://www.searspartsdirect.com/part...Mod=LAT9306AAE
Or the transmission is bad.
