Whirlpool washing machine just stopped, mid cycle
Old 10-19-12, 04:27 PM
A
Hi everyone,
i hope someone can help me. I have an old whirlpool washer. The other day it just stopped working mid cycle. The water is still there and won't go down. No cycle will start.
Do you know what could be wrong?
Old 10-19-12, 05:40 PM
Received 1,167 Votes on 1,082 Posts
Could be a number of issues. Did you check the outlet that the machine is plugged into ? If that's good you could have a timer problem. On the older machines the door switch only controlled spin so I doubt that is your issues. Sometimes you can push-pull (start-stop) the timer knob a few times. Another thing to try.... put machine into wash cycle......move water level control from hi to med to lo. Does that make the machine do anything ?
Old 10-19-12, 06:48 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
post model # can help to know what washer we are talking about.
Old 10-19-12, 07:07 PM
A
Thanks for lithe suggestions, but they didn't work. I tried turning on every cycle and nothing happens. Not even any motor sound. I changed the water levels too.
Old 10-19-12, 07:10 PM
A
Hi pugsl,
pick don't know the model number. Is it on the washer somewhere?
Old 10-19-12, 09:37 PM
Lift the lid. Should be in the back there under the lid. A metal tag full of old soap. Sometimes you have to squat down a bit to see it.
I'm guessing you also checked the outlet and found it to be working ?
