Kenmore 80 Series washing machine - no spin, no drain.
Received 0 Votes
Serial No.: 110-92380200
Symptoms - Machine was working fine. After rinse cycle, doesn't drain, doesn't spin. Humming sound under machine at motor.
I thought I saw the answer in another post, but I couldn't find the post again
Any and all help is greatly appreciated.
Thank you
- I replaced the coupler one week ago. Re-inspected, no cracks or wear (completely pulled apart did not just visually inspect).
- No oil on sides or ground of machine
- I took off the water pump, tested motor. Did not spin, still hummed. Pump spun easily on its own, no obstructions.
- Dropped motor down, spun fine and adjusted to the cycles.
- Reconnected - does not spin, makes humming sound.
- Lid switch in proper working order (with the motor spinning once dropped from assembly lets me know its not the switch). Switch also makes the proper "clicks" is not loose and is snug against housing.
Thank you
1 OF 2 Things I can think of. 1st most likely is something under basket, Have to take basket out to check. While basket out try spin cycle again if still no spin than you have a bad gearcase. Just though of a third thing which I don't think you have.
Tilt washer back against wall and look under it. About 6 inches up around cabinet see if there is a streak of oil. If there you need a gearcase top seal, clutch and drive coupler.
Received 0 Votes
Thank you for responding. I will check the basket.
Previous I did read the threads and saw the issue about the oil... zero oil in the cabinet as stated, but thank you so much for responding. I saw how to take the basket out, just have to find it again.
Received 0 Votes
I can't get that dag nab tough nut off. It looks like there is some locking nut/washer on it which I can't find a way to get off. While I don't have the spanner wrench, nothing else I used could even begin to budge it.
While I will go to sears and get the spanner, I am really concerned about that possible locking washer etc.
Any thoughts on this?
No locking washer what I think you are seeing is the top of the drive block, has 2 slots with tabs in it. Go to appliance parts repair store for spanner wrench. Have a heavy hammer to use on it. I have a 2 or 3 pound to use on it. After nut off basket should lift out but sometimes is stuck to drive block. Most times you can work it off after a while.
Received 0 Votes
Welp while I found a lot of old dirt, nothing was actually blocking it. I turned it to spin... same humming, shaft was not spinning. So I guess its a gearcase?
BTW I am looking for the gear case in the parts list, are you talking about the transmission?
Please know I appreciate all your help.
Part # 9 is gearcase
http://www.searspartsdirect.com/part...od=11092380200
Google Whrilpool gearcase and you will find lots of sites that have them and also how to rebuild. One site has a video of rebuild.
I guess your washer is about 10 years old, if newer less than 5 years and it has a plastic timer in it I have seen the timer do that. Timer will make motor try to run in 2 speeds at once.
Received 0 Votes
Well Pugsl I am blown away. I got the gearcase today, installed it without a hitch. I get it all put together, but before I brought it into the house I wanted to test the spin cycle. I get nothing but a hum.
Any other ideas?
Any other ideas?
you have a different one, I have seen this on newer washers but not on your model. Newer one's have a plastic timer and that timer will do the same thing. If you lay motor on floor and try to run in spin cycle does it still hum? Speed switch could do this also. What I am guessing is motor is trying to run in 2 speeds at once. I don;t have wiring diagram so can't help with that.
Received 0 Votes
Just for accounting...
When I disconnect motor from gearbox (but still connected to the pump) no problem it works (aka it spins). Soon as I have it connected to the gearbox, it just hums.
