Kenmore Washer Not Agitating/Spinning
Old 10-28-12, 10:29 AM
C
Our Kenmore washer (70 Series, Model 22722100) recently stopped agitating and spinning. It fills up OK, and then when it should agitate or spin, there's a hum like the motor has seized up.
Is there much to replacing the motor on this model?
Old 10-28-12, 03:51 PM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
Lean washer back against wall, unclip water pump (leave hoses attached} Set washer back down and try spin cycle. If starts to spin you have a sock stuck in water pump and most likely will need a water pump. I very much dough you need a motor.
