Kenmore defrost water leaking onto floor
Old 10-29-12, 09:43 AM
My Kenmore side by side refrigerator model 363.9557752 has water leaking out from inside of the freezer coming out from the front at bottom of freezer door when it defrost. I am sure it is a clogged freezer line / drain pan issue but I do not know how to fix it. Any help would be much appreciated.
Old 10-29-12, 10:52 PM
You'll need to shut off unit and take the food out of freezer. I left you a link below to the inside of your freezer. You'll need to remove the cover of the evaporator in the lower rear portion of the freezer. Locate the drain tube and clean it out. Running hot water thru it will work. Otherwise you may have to remove the tube to clean it out if it's really plugged good. In the pic it's part 225.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-3639557752/0582/0165000/10044282/00004
Old 10-30-12, 04:43 PM
Thanks. I will try that. Hopefully the hot water will work.
Old 11-01-12, 09:46 PM
Your advise resolved the problem. Thanks.
