Kenmore fridge not cooling
Old 11-19-12, 08:25 PM
2001 Kenmore side by side not cooling right. Inside freezer and fridge the inner walls are cold at the bottom but almost room temp at the top. Fans are not running in the freezer or fridge, The compressor is warm and the fan there is working. I believe its running. The ice maker also stopped, with very little water coming out of the front dispensor on the door. Not sure if this is a separate issue. No frost on the inner walls.
Old 11-19-12, 08:54 PM
Received 345 Votes on 323 Posts
The coils are in the bottom of the freezer which is why it's cold there. Basically the fan blows air over that coil thru the freezer and into fridge. That's called the evaporator fan. With a model number I could give you its location and probably how to get to it.
Old 11-19-12, 10:17 PM
I'll see if I can get it. Its actually a friends fridge, but she's works 2 jobs.
Old 11-20-12, 07:17 AM
Model # is 52299100.
Seems I need 25 characters to post a reply? ok
