Slow spin
Old 11-22-12, 06:16 AM
W
Question Slow spin
Whirlpool model WFW8300SW04, front loader, won't spin on HIGH unless the washer is empty, and then it only spins slowly. It drains, but clothes are super wet because of no spin.
Old 11-22-12, 10:48 AM
Received 3,610 Upvotes on 3,236 Posts
junkman ......your link won't work for us. Also you're missing a number at the end in the model number listing. In your picture you are holding what looks like a water pump. That one looks to be belt driven but your machine doesn't show that.
The following link should be close to your machine. You may also have a belt issue.
Whirlpool Washer LHW0050PQ1 Complete Parts List
PLEASE double check model number of machine.
Old 11-22-12, 11:16 AM
Wolverdog....similar parts listing for you......may be a slipping belt issue.
Old 11-22-12, 03:13 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Have never seen your problem. Your washer either spins or not. Open lower panel and there is a tech sheet in there either in panel or taped to side. It will tell you how to read error codes or tell you how to do a test cycle. Moved your post to it's own thread.
Keep us posted. Been working on them for last 10 years. You said no noise, Try this, reach inside washer and move basket up and down. If basket moves in tub you have a bad bearing. Just basket not the whole tub.
